Arlo App Alarm Trigger Notification and Scheduling questions
Is there any way to have the Arlo App alert the smartphone or send a push notification that the alarm is triggered?
My other question is more of a suggestion that I hope scheduling in the app slows geofencing.
Not sure exactly what you're asking. Push notifications are available for any detected (motion or audio) event. However, if you're asking for a notification for when the siren is manually activated, there's no notification.
Be a bit more specific as to what you're after.
