I created account many years ago on netgear website. Is a way to get support for Arlo system as I'm located in UK and based on Arlo UK Support my account is in the US support system?
Do you mean you set up an Arlo system (while it was still owned by Netgear) previously? Where did you set it up - in the UK or the US? If the US and you want to utilize the UK support, you likely should remove your account via Settings, Data Privacy, Account, Delete Arlo Account and then set up the system as if you just bought it. By removing your account and then setting it back up, your current location will dictate which support site you connect with.
Yes, system was setup while it was owned by netgear. It was set in UK and still run in UK. It has UK address on account. I pay for subscription / cloud recording. Recently I get issues with one of Arlo devices and try to contact Arlo support. But they was not able to find my account. So they escalated it to European Arlo support and I get answer that my system registered in US support, and I have to contact US Arlo support. But when I try to contact US/CA support, I get message that my regional support team is in UK, and I need contact UK Arlo support.
lexxmt,
I've checked the account associated with the email you're using here on the community and it is associated with a EU country code. I recommend contacting EU support using the Arlo mobile app under Settings > Support. If you continue experiencing any issues, please let me know.
This what I get from EU Support Team:
Your Case Details
Case Number: 00529361
Subject: issue onboarding doorbell
Case Update
Dear Vitaly
Thank you for getting in touch with Arlo Europe support.
This is Jacob from Arlo Europe support. I am just following up with you about case 00529361.
Looks like the XXXXXXX account is in the US support system. Maybe you have created it abroad (outside of the EU) or you were using VPN and you just do not remember.
Please contact the US support for assistance with the doorbell issue - https://www.arlo.com/en-ca/support/contact
lexxmt,
I've opened and escalated a ticket detailing the concerns you've mentioned here. An agent will reach out to you with a status update as soon as possible.
Any updates?
lexxmt,
I've been informed that your ticket has been routed to the appropriate regional support and an agent will be reaching out to you with more information.
My case not progressed so far. It get closed. So I’m on same place where I was
case:
Your Case Details
Case Number: 43456942
Subject: EU customer being router to NA support
Product:
Case Update
Dear Vitaly,
Thank you for contacting Arlo Customer Service and Support. You have reached the support team for customers outside of Europe.
To comply with the GDPR and other relevant Data Privacy regulations, our customer databases are independent from each other. Unfortunately, we are unable to assist you today.
lexxmt,
Looking into this again, I apologize for the delay. I will let you know the results as soon as I have more information.
Any news?
