I already have an ARLO 4-camera system and recently purchased and additional 2-camera set-up and see that i can only stream 5-cameras at teh same time. How do i view the 6th camera and/or do i have to install the 2nd base station in order to do so?
you can run two bases each under separate accounts and then share acces via the GRANT ACCESS.
Or you could also pay for the next level which will allow 10 cameras if needed.
