Arlo 3hd Security camera kit
  • 2 Replies
  • 3082 Views
Bartie
Bought this system on 19th March.....Easy set up ...it says on the box......Ye right.......after eventually getting everything set up,one of the cameras doesnt seem to be working properly.......it picks up motion and only records sometimes and when it does record the image is green and flickers.Ive pulled the batteries out,reconnected it,put new batteries in because it was showing that the batteries were low ... Ive also tried repositioning it...still no joy,I think the next step is to throw it in the bin...
Swap the camera with another and see if the problem stays with the camera or the location.  If the latter, it sounds like the connection between the camera and base is the problem, possibly due to obstructions and/or interference.  If the former, create a trouble ticket for help and possible RMA.
Bartie
Sorry for the slow response....Ill give it a try and get back to you
