  • 2 Replies
  • 3522 Views
RichardNZ
Hi All,
Tried searching but unable to find if this has been asked before.
Are there any plans to add a security layer to the Arlo app so that when it is launched it requires a pin/password?
While I use security lock on my phone i would like to see an additional layer of security so you cant just launch the app and go straight into a live feed. Would be great to at least have this as an option within the app.
Cheers
steve_t
Master Master
It's designed to have a login password but if you clicked "remember me" or whatever, it will open without needing the password. You could add the requirement for a fingerprint as well IIRC
Yes...also if you really log out in SETTINGS, the app should require a sign in with password
