App disconnecting
Since it seems you have the issue on the Ipad and not other devices... I would recommend you uninstall the app and the re-install.
See if that fixes the issue
Clnewell,
Have you tried relocating that camera closer to the base/router to see if you get the same behavior? It sounds like interference could be causing an issue.
Clnewell,
Possibly, I encourage you to open a support case for further investigation: Arlo Support Team
Don't feel bad I am having the same issue. 1 out of 4 cameras work and the 1 camera is outside and the three others are inside within 20 feet of the base station. They must have currupt firmware. I dred calling customer service in another country to help. The worst customer support and they are not trained on must issues. I was hoping to see a resolution on your post. If you did get it resolved please post back. Thanks Randy
If you don't try support, you get what you get. We can try to help here but sometimes a case is needed, especially to get it escalated.
I have a case# 29210635. Just FYI first level support is useless. I posted on here in hopes someone may bring this thread back to life. Not to be combatitive. So if you have nothing to offer or any solutions find another place to play. If you know what the cause of this is mention it.
We can't fix hardware or corrupt firmware here. You can tell us details about what happens, what you see and any error messages, what you've tried, etc. in detail so maybe we can help. This is a user forum, not a support mechanism that can replace hardware, etc.
