I need to swap out my base station. Are there any recommended or needed steps, like.. do I need to remove cameras from old base / remove from site first? Or can I just remove the base station from the account and just add the cameras to new base?
Since the cameras are associated with the base, you'll need to remove all devices and start over as fresh. Note any settings, modes/rules and schedule before doing this. I'd suggest a factory reset on the old base before unplugging it.
Got it.. Do I have to remove cameras from account or should I just add them to new base?
They should al be removed from the account in Settings, My Devices. You're starting fresh.
