Amber power light on base station
My 3 cameras and base station were working fine for months, then all of a sudden my base station stopped working. I tried the turning on off, unpluggin, resetting etc, but only get a amber POWER light. Has it died? I no longer have the receipt, but it's less than 6 months old...what are my options?
If the first from left LED is amber...thats the power LED. It should be green. It's either the base or the power supply.
Contact Netgear support... warranty is one yr
