Amber internet LED
  • 1 Reply
  • 2916 Views
601summit
I have sync the cameras with base station. I have ethernet cable i
plugged in to base station and router. The router # 4 port light is amber. Can not get it green.
Darty
If the base (not router) Internet LED is amber, that means connection to the router is there but the base isn't connecting to the Internet servers.  That implies an issue with the base or router.  Try power cycling both and see if that helps.  If not, try resetting the base by using the reset button until the LEDs flash amber.  Let the base initialize (~2 minutes) and see if the Internet LED turns green.
Any luck?
