Amber internet LED on base station VMB3500
New out of the box VMB3500 Base has Amber Light. I have done the following. Can anyone help me?
-reset router
-reset base
-opened ports 80, 443, 123 on windows
-added port forwarding for ports 80, 443, 123
-added port triggers for ports 80, 443, 123
-turned off the firewall in windows and on the router (I have turned them back on after testing it to see if that fixed it)
Is there anything else I can do?
Have you tried a different ethernet cable?
What ISP? Who owns the router? Define "reset".
Next step would be to take it to another location to check if it works. Failing that, seek an RMA either via the retailer you bought from or from Arlo support
I have tested it it three stations I have with ethernet cables with no luck. I will open a ticket with support. Thank you for your suggestions.
