All systems
  • 1 Reply
  • 3133 Views
Drudd
Will your systems work in south africa? They use 230.240 volts but not sure re IP adresses?
IBOMK, it should work in any country that has internet access BUT may only be on the BASIC level...and needs 1Mbs upload min
this is because some locations are not supported on a higher level of service...basic is free to a max of 5 cameras with 7 days of rolling storage
For the Pro and Q cameras I believe the adapter support  120-240v directly  , but the base units  power for Arlo and ArloPRO would need convertors to drop the 220v ac to 110 v ac
see also https://community.netgear.com/t5/Arlo-Pro/Arlo-Pro-Smart-Security-System-with-2-Cameras-VMS4230/m-p/...
