  • 12 Replies
  • 3689 Views
avict
I've got the orginal arlo base station, 6 original cameras, 1 pro and 4 Qs
A couple of days ago the 6 original cameras started to report that they were offline and I've spent quite some time trying to get them back up and running to no avail.
I have:
- replaced the batteries
- removed the cameras from my dashboard
- factory reset the base station
- moved the base station to a different location in the house
- tried changing the main wireless router's wireless channel
- tried changing switching off the main wireless router.
- got 3 lights on base station - that all looks good
Through all of this I cannot get the 6 original cameras to sync/connect. Occasionally I will get one to sync, but it will immediately go offline.
The Arlo pro camera has worked fine throughout.
I would suspect a deaded base station, but doesnt explain why the pro camera continues to work fine.
I had a wild theory that a patch was rolled out to address the Krack WPA vuln and my stuff can't talk?
Base:
HW VersionVMB3010r2
Firmware1.9.0.0_14639
Camera:
HW VersionH7
Firmware1.2.11810
avict
after a bit of back and forth with support I suggested that they replace the base unit - they've done so & seems to work ok now
12 REPLIES 12
avict
p.s. Netgear support broken?
If you used the reset button until the base LEDs flashed amber, you also need to remove all devices associated with the wireless system (not the Q cameras) from Settings, My Devices. Not removing them may well be the issue. Remove the cameras and the base and start fresh.
avict
cheers for the tip, but I did remove everything bar the Q's - cameras first, then base station from devices..
Added the Pro back on fine, standard cameras I can (after a loooong connect time) get to re-sync sometime but go offline immediately.
I'll give it another go to be sure!
avict
been through process again as described - see below pro works fine, any of other standard arlo cams struggle to get added & wont stay online
dragonrb
have only 4 cameras and one keeps going off line.. re sync it last for two days maybe three and go off line..tks
I think opening a case with support using the Contact Support link at the bottom here.
Karenbrrl
Were you answered? I didn't find an answer in the thread but I'm having the same issues.  They are either offline or "busy" or the batteries are dead.  It really hasn't served a purpose for me except climbing up and down ladders and searching the Internet for answers.  EVERY time I've needed to look at a video that Arlo should have captured, it's "busy".  Just checked them today and at home all four were offline.  At work, the one that is working only had one video over the course of 3 days - which is not true as trucks are in and out all day long.  Really want to switch security systems!
avict
I did that a few days ago & have recieved an acknowlegment but nothing further as yet
Thanks for your suggestions, much appreciated  🙂
I've also ordered a second (pro) base station to have a play around with tonight to see if that makes any difference (hopefully I can get both working and distribute the cams to get a stronger signal subsequently).
avict
I think they might have had a problem with their support system - the site was down when I checked several times & it took them 24 hours to send a first response
avict
As a quick update, my new Arlo Pro base station arrived today and I got all the cameras up and running fine pro / non-pro.
Not sure if this means there is a fault with old base station or a bug with gen1 cameras / gen1 cameras / gen1 base stations. To reiterate,
-my arlo standard base station and cameras will not work together.
-arlo standard base station and pro camera will work together
- arlo pro base station and both types of camera work together.
avict
P.s. will let you know the outcome of the support case 🙂
avict
