All Cameras Are Offline On Two Base Stations
  • 6 Replies
  • 1955 Views
Cmcg921
Was there an update recently that would have caused base stations at two separate addresses on two separate routers to go out of service? I powered off one router and the app sees that router but none of the cameras will connect. I will not be able to look at the other base station until this weekend..
6 REPLIES 6
Last base station update is listed as the 7 th
Mdhaberl
I too am having the same problem since the recent upgrade. First it said they were offline. Tried to resync and would not connect then tried to remove the device re-add and resync and still nothing. Any help would be appreciated.
I am afraid as this appears to be connected to the removal of the basic plan which I am a bit frustrated about as this is why I chose this product . The plan was a part of the product that I purchased and now they are taking that away...
Mdhaberl
Did you ever find a solution to this? I am still having trouble connecting my Wire Free cameras to the Base Station. I was able to connect my ArloQs.
ShayneS
@Mdhaberl
What firmware version is your base station & cameras running?
Mdhaberl
1.12.0.1_97240 is the version. Says there are no other newer versions and I don’t know how to revert back .Any help would be great.
ShayneS
@Mdhaberl
Have you tried to reboot your cameras by opening the battery door?
