  • 1 Reply
  • 851 Views
Stefania18
I recently purchased Arlo cameras and after installation I have a Adobe Flash problem every time I open the Arlo app. I need to do several steps to allow the Flash to my app. I see at this site it seem to be this software is not working in accordance to the Adobe Flash. Crome does not allow Flash as a default.
How is it; are you going to continue to support Adobe Flash when Crome is going to skip it out very soon? The cameras seems to be work very well, but the software with Flash not.  I am very disappointing with this issue.
Stefania
All of us would love to see Arlo move away from flash.  That said, ...
It shouldn't be that difficult.  Just click on the padlock after you log in, and then "Allow" flash.  FWIW, on my system Chrome will remember that setting, so I don't need to re-apply it on every log in.  Though I do need to sometimes set it again.
@Stefania18 wrote:
...are you going to continue to support Adobe Flash when Chrome is going to skip it out very soon?
"Very soon" is Dec 2020 - still over a year away.  Obviously Arlo will need to transition before then.
