Additional home cameras
I already have Arlo at my home. How do I create another account for my second home?
It partly depends on whether you see Library to view recordings or Feed - the current app supports both. If you see Library, just use a second email address for the new account. You can then use Settings, Grant access from that account to the original account's email address so all cameras show in one login. New cameras require a subscription.
If you see Feed, you can use the same account. Create a new location and add the new cameras to that. Note that each location needs its own subscription, depending on whether you're using older legacy cameras or new cameras that require a subscription for cloud recordings.
