  • 1960 Views
smdnm
I need to add a wirefree camera to my base station.  I pressed the sync button on the base station, then the button on top of the new camera, but no link was established.
If I press the sync button on the base station, will I lose connectivity with existing cameras?  What am I doing wrong.
When I try to add a camera, it says no new camera detected.  Thanks.
It should be easy....
Just press the base sync button ( do NOT hold ) quickly ( you should see the led on base flashing ) and then the camera.
slow blue on camera to fast means it worked
smdnm
I was not logged in as the primary user.  I changed log in and there it was. No info on that issue.  But fixed.  Thanks.
A new camera doesn't automatically show for a person that was granted access. The primary must go into that person's settings in Grant Access and add the camera.
