I have 4 ARLO VMC3030 cameras with one Netgear base station. I have the Premier Annula Subscription. My question is: Can I add 2 more VMC3030 cameras to this base station? Will is record and monitor all 6 cameras? We are just thinking of getting 2 more, then all 6 cameras would cover the outside of our house all over. Thank you, Joni
the upper two levels support 10 then 15 cameras total , so either way you are good 2 go.
The Base units can ONLY support 5 streaming cameras at the same time... but, this usu isn't an issue even with the 12 cams I run.( unless they go running thru all your cameras 🙂 )
Thank you. So I'm pretty safe to purchase two more cameras and run them off same base. I gave a RING DOORBELL too and I love it.
Max number of cameras is 5 for the Basic service level ( free ) , since you have a paid level, all ok
