Added a camera and it is not picking up motion
  • 6 Replies
  • 3667 Views
Bez
I have added a further camera and it appears it's not picking up motion at all, I have tested the motion in settings to no avail, I have re synced it and turned off at base plate no avail, the running man is grey. It picks up live when testing but that's it! I have the app on my tablet and use that...no problems with the other cameras at all!! Please help before I send the device back.
thank you in advance.
If the running man is GRAY, it will never pick up motion as the camera is not armed !
When the camera is armed, the running man will be BLACK.
Check your MODES to make sure the camera rules are correct.
6 REPLIES 6
steve_t
Master Master
If in test mode, it's not picking up any motion, I suspect you have a faulty camera
Bez
Thank you Steve_t I thought it might of been the case, I shall send it back 😞
again thank you you for your quick response.
Bez
Thank you Tom Mac, that's exact,y what I did and your right, it's now working 🙂 totally appreciate your help.
steve_t
Master Master
Good result, but I'm confused.
If you're in disarmed mode and go into the camera settings and use the motion sensitivity testing, it doesn't work??
Bez
Hiya, my fault I had not set the mode for this camera, now that I have it works 🙂
