Added 2 Arlo Pro 2 cameras (VMB3010r2) to Base. Will not show any details like battery/wifi signal.
  • 7 Replies
  • 2168 Views
Cbert210
I added 2 arlo pro 2 cameras to this base it will not show any details like battery wifi signal
Cbert210
Figured it out uninstalled my app reinstalled app works fine
7 REPLIES 7
Have you rebooted the base?
( power off then on ) and wait 2 mins to come back and check icons
Cbert210
Yes I have
Cbert210
I have 5 cameras 2 are the pro 2 and wont show device info
Are they showing as off-line?
Have you tried taking the batteries out of the cameras and then reinserting them?
Cbert210
They work they just aren't showing wifi battery or any device info
Cbert210
It did not work removing battery
Cbert210
