I added 2 arlo pro 2 cameras to this base it will not show any details like battery wifi signal
Message 1 of 8
1,231
Figured it out uninstalled my app reinstalled app works fine
Message 8 of 8
1,173
7 REPLIES 7
Have you rebooted the base?
( power off then on ) and wait 2 mins to come back and check icons
Message 2 of 8
1,211
Yes I have
Message 3 of 8
1,208
I have 5 cameras 2 are the pro 2 and wont show device info
Message 4 of 8
1,204
Are they showing as off-line?
Have you tried taking the batteries out of the cameras and then reinserting them?
Message 5 of 8
1,183
They work they just aren't showing wifi battery or any device info
Message 6 of 8
1,181
It did not work removing battery
Message 7 of 8
1,179
Message 8 of 8
1,174
