Thanks.
If you have your father’s credentials you can remove the devices from his account and install on your account. Just be aware that there is a 5 camera limit per account without subscription plan.
If you’re unable to access the credentials then you will need to contact arlo support which now requires a subscription plan.
One of the mods might be able to help escalate ( @JessicaP , @ShayneS , @JamesC ).
My dad set up the main account but I was invited (I think) to create my own account, which was done years ago. There are only 2 cams. I also have the cameras showing in my acccount (at least their views). Do I need to remove them from my dad's account if they already show under mine? What do I need to do with my dad's account?
Login to the web portal with a pc on the same network using your father’s credentials and remove the devices manually starting with each camera then the base station.
Then login to your account and add the devices.
Once you’re happy that they have been installed and working for you, login to your father’s account and remove any grant access account to remove yourself from his account.
If you’re then happy, private message a moderator here on the forum to have your father’s account removed.
I don’t know if it’s possible to transfer an account but a question for the moderators, @JessicaP.
Thank you for the advise. Since I already have an account where the cameras already show, am I only getting the view as a user but need to access the main account to have full control? I'm just trying to figure out the best way of handling it. If there was a way to make my account the admin or whatever it needs to be and close my dad's account, but that may not be how it works. As previously mentioned, perhaps the mods may have some insight. @JessicaP @JamesC @ShayneS
Correct.
You have two options:
- remove the cameras and base from the primary account, and add them back to yours. Then ask @JamesC to remove the old account.
- Ask @JamesC to remove your account, and then change the email address on the primary account to yours.
I'd be inclined to go with (1), but maybe wait and see what JamesC has to say.
shadespkb,
If you would like to consolidate the cameras to one account, remove the cameras and base from the account and then re-onboard as new on your primary account.
James,
Thanks for the advise. Is there a help document that explains the process of removing the cameras and re-onboarding?
Thanks,
David
https://kb.arlo.com/1713/How-do-I-remove-a-device-from-my-Arlo-account
https://kb.arlo.com/1088401/Can-I-add-an-additional-Arlo-device-to-my-existing-Arlo-camera-or-system
Note you need to remove both cameras and base stations.
The first link says that all settings will be erased. Is there a way to back that up first? I imagine I can view the settings and make note of them. Keep in mind that it was my dad who set it up so I don't know what the settings are. Would you recommend copying or somehow making not of the settings first so they can be replicated?
Thanks,
David
The settings are saved in the account, so they will be erased. There is no way to back them up.
So you will need to look at them, and make a note of what they are. Though I think this depends some on whether you are planning to keep the cameras at their current location.
In addition to the camera and base settings, you need to look at the modes (and the rules in the modes), as well as the schedule (if set) and geofencing (if set).
