I'm trying to figure out how I access my Arlo Cloud recordings from my new security cameras
If I understand your post correctly, in the mobile app and on the website go to the tab that says Library. All the videos that have been taken should be there for the number of days for your plan.
Brian
I bought the ELITE plan. I have purposly set off the cameras to see how things work. My library still is empty. I should be able to see live video.
Liveview and recordings are two separate things. Any recordings are stored in the library. If you have a filter set in the library only those cameras selected in the filter will be seen. If the funnel icon is filled green, a filter is set and may need to be cleared to see all camera recordings. Click on the funnel and reset. Be sure to Save or use Done, depending on what you see.
