My ARLO Security Camera works fine with my cell. When I am out of the States I can not use my cell and I want to use either my loptop or IPad.
How can I use those ?
Than you for help,
Valeriu
To use a laptop just use a browser and go to https://arlo.netgear.com
To use an Ipad, you must first get the ARLO APP from the apple store and install ( free)
Same for Android, go to google store and it's free.
Also, note that you can use a mobile browser if you use the browser's menu to tell it to use the desktop version of the Arlo website. Otherwise, you'll just get a page that tells you to install the app.
