I moved locations switching my IP address, and now my ARLO base station is not being picked up when I try to connect it. The lights are flashing light green, but some reason it will not connect still. I tried resetting it, connecting and unconnecting everything, and still nothing. Can someone please help me?
Did you also get a new router? One thing you can do is look at the attached device list in the router, and see if the base station is listed.
Yes, I did get a new router! Where do I find that list?
It's in the router's web ui.
Hi Stephen,
Where do I find that web ui? I am not tech savy, so I apologize for all the questions! Thank you again for helping!
It kind of depends on the router.
Most times it is either http://192.168.0.1 or http://192.168.1.1
What router model do you have?
