  • 2 Replies
  • 4539 Views
  • 2 Likes
SteveL-W
This afternoon I suffered from a brief power outage that killed everything in the house. Since restoration, both my smartphone and iPad are showing the router, and both wireless cameras, as offline.
I have checked the cabling, rebooted the router several times and even pressed the router's reset button. All to no avail. The router is showing the first three indicator lights on the panel as green, with the other two not illuminated.
The app has allowed me to disconnect one camera. When I attempt to re-connect it, I get all the correct flashing green and blue lights, and then nothing. Device simply will not connect.
Is there anything else I can try?
steve_t
Master Master
With a hard reset of the base station, you should have had to reconfigure everything from scratch. You probably need to hold the reset button down with a pen or paperclip end for at least 10s
Then go into your Arlo app and start again with a New System Setup
steve_t
Master Master
SteveL-W
Great. That seems to have solved the problem.Thanks
