ARLO 2 pack camera
  • 1 Reply
  • 2982 Views
Headski
I hooked up the base system and tow cameras and everything works great. I pluged the base to the router directly. However, it is causing my wi-fi to be intermittent and not let all of my other devices work properly. I have the highest internet plan with Time Warner. Any help would be appreciated. I also have a NEST camera connected thru WIFI.
The easiest thing to try is to reposition the base via a longer Ethernet cable or plugged into a WiFi extender so the base is further away from the router and will allow the base to choose a different channel to operate on.
