APP Filtering
  • 4 Replies
  • 2857 Views
Jemima
After the recent App Upgrade (2 days ago), I can’t find an option to filter recordings by Device. I have 5 cameras. Before the upgrade I could filter recordings by device. Now I can only filter by date and the feed includes recordings for all 5 cameras. How do I view recordings for a specific camera only please? Using the App on an iPad.
Thanks for the help.
Since you mention Feed, click on the 3 dot menu at the top right of Feed to set filters.
Jemima
That doesn’t work for the version of the App I have.😊 I’ve got a Dashboard with  3 options ‘Arm Away’, ‘Arm Home’ and ‘Stand By’.  When I click on the 3 dots as you’ve mentioned, it takes me the widget for the cameras.
Before the upgrade 2 days ago, I had no issues with filtering and everything worked as you described above.  Now with the new version of the App, one can filter on days but I can’t find a way to filter per device.
Huh….
As I said, click the menu icon in Feed, not Dashboard.
LBK12
We are having the same issue. We can exclude Animals from the feed, but now we can’t set that by camera. It is all cameras.
