Arlo ABB1000 is not powering ON
I was trying to configure it and it asked for Firmware update, in the middle of the update it went off and now not powering ON at all, no lights no blinking nothing at all
Any suggestions on how to turn it on now please
Have you tried performing a factory reset while plugged in? How do I perform a factory reset on my Arlo Bridge?
Yes tried to do factory reset, however no luck as there is no light on the bridge ( no solid blue or amber light)
Not sure if it's powering on or not is there way to fix that?
Have you tried various outlets in your home?
Yes tried different sockets and at neighbor house as well
