32 Caracter Geofencing Error Saudi Arabia
Good Day,
Im still facing the "32 caracter forward slash" error while setting-up the geofencing. Im in Saudi Arabia and all addresses are longer than 32c. Also there are some Arabic and Urdu caracters from the App Map itself and nothing can be changed manually. If you type your address from scratch the app will force you to choose the one most similar to the ones in its database (and those are longer than 32 and have arabic/urdu caracters on them).
fdeluna,
Are you able to provide a screenshot of the error you're seeing?
HI,
Are you still experiencing this issue?
