30 days of Video history
Hello,
I am using Arlo Secure with "30 days of Video history". However, the video is discontinuous. And it is not 30 days.
1. What should I do to access history video in last 30 days?
2. Should I need to buy any other plan of Arlo?
Thank you so much and looking forward to support from community!
@DynastyJeweller wrote:I am using Arlo Secure with "30 days of Video history". However, the video is discontinuous.
Correct. Recordings are made motion is detected. It can also be set up to record when audio is detected, and recordings can be made manually.
Some cameras support continuous video recording - though that needs a different subscription. Also, the camera needs to be AC powered (not run on battery or solar).
How far back does it go?
