3 brand new cameras. Settings all checked. Why are they missing obvious motion detections?
Because your motion detection sensitivity setting combined with your camera placement are not optimal
Positioning is key. Like any PIR detector device (think motion-activated lights), motion AT the camera is harder to detect than motion ACROSS the FOV. Post screenshots of what the camera(s) see for suggestions.
"High" isn't a sensitivity setting. A car at 20 feet should be fine but you'll need to increase the motion sensitivity from what it is stock standard
I would try to tilt the front camera down some to help minimize the view. I'd also turn it to the left in increments to get action more across the FOV but it's rather limited to do so. For the back, the view across the yard is the killer. People detection is only 20 feet or so, best case so placing the camera closer to where action is anticipated would definitely help. It may require 2 (or more) cameras if you really need to cover the whole yard. You could then use nested rules where one camera triggers another, like this:
cam1 detects, cam1 records
cam1 detects, cam2 records
cam2 detects, cam2 records
cam2 detects, cam1 records
etc.
