3 Arlo cameras showing offline
Have five cameras set up. Have rebooted a number of times. Three cameras say system is offline, the other two are fine. Help is appreciated.
When individual cameras are offline, chances are reasonable that they have either lost communication with the base station, usually from being out of range, or the batteries are flat.
Check the batteries. In opening the battery compartment, you'll restart the cameras if the batteries are fine anyway and it should sync up again
I'm away now, can it be done remotely?
The other day I had a camera show as offline. I remotely restarted the base station through the app and lo and behold, the camera was online again. Give that a shot and maybe try more than once. If the batteries are flat, though, it obviously won't come back online
Sometimes simply force closing the app or lgging out and back in works, too.
