Hi I have two arlo wireless cameras. The one that is not recording shows the same exact time the other is recording motion. I tried re syncing the one not recording but that did not work. I would appreciate any help.
Joe
Have you checked that the RULES in your recording mode are set correctly?
Rules are identical for both
The one that isn't detecting motion - is the 'running man' symbol above the device preview image black or grey? Can you live view with it?
