Hello,
I was trying to monitor my cams today and of my 5 cams, one os showing offline. All other cameras are working perfectly.
Help?
For those involved in this discussion, you may be experiencing a camera offline issue due to the most recent camera firmware release.
For troubleshooting information on this topic, please take a look at this article: My Arlo camera is offline since the release of the recent firmware update; what do I do?
If you are still experiencing this issue, please let us know or feel free to private message me, I would be happy to help.
Hi bobbydigital,
Welcome to the community!
Kindly try to resync the camera that shows offline. Check this link below and follow the steps on how to resync your camera to the base station:
Resync your camera to the Arlo base station
Kindly check also the distance of the camera that shows offline if its within the range of the base station. Check this link below as reference:
How far from the base station can I place my Arlo camera
Furthermore, you may isolate the problem by swapping another camera to the location where the camera that shows offline is deployed and check if same problem occurs.
I am looking forward to your response.
Regards,
DaneA
Netgear Community Team
I am currently experiencing the same problem as this customer. Performed all the troubleshooting as you've mentioned. Two cameras are placed at the same location zoomed in at different directions. One is getting good signal, the other is not. What can i do?
baktun,
Is the camera showing offline in the UI? Consider installing a fresh set of batteries in the affected camera. Do you still see the same behavior?
Yes, swapped out the batteries for fresh ones and it's still exhibiting the same issue.
Baktun
Power cycle the base. Remove the camera from Settings and resync. Have you tried swapping the cameras between positions? Does the issue follow the camera or the position? Put the camera in a totally different location and see if it follows the camera. Also, what does the LED on the front of the camera do in the various stages of troubleshooting?
Since you've tried the camera near the base with poor success, I'd suggest a trouble ticket for help and possible RMA. I was wondering if the close proximity of two cameras could be causing issues but your moving it to be close to the base eliminates that.
baktun wrote:
Thank you jguerdat. Now who would i be putting in a trouble ticket with?
You have four options of getting in touch with Arlo support:
- Web form,
- Online chat,
- Telephone,
- Trouble Ticket.
#1 thru #3 are accessible through http://www.arlo.com/en-us/support/contact.aspx, which you can also get to by clicking on Support on every forum page, and then Contact Support.
#4 is available at https://my.netgear.com. Register or log in to directly submit a trouble ticket.
Juju52,
What device is indicating as offline? Are you getting an Amber internet LED on the base station? Are you seeing any error messages?
You can try power cycling the base station (using the on-off) button on the back. Allow the base station to come back online with a solid green power and internet LED.
Please give us more details about the issue so we can help.
