No way to disable LED on wired floodlight cameras?
  • 2 Replies
  • 546 Views
Chad4444
I want the floodlights to never turn on.  Is there really no way to do this in the app?  All you can do is set brightness to the lowest level, but not off.   I still want it to record video when there’s motion and record in dark via the infrared night vision.
In your rules for the camera, ensure that you either don't have an action for the floodlight or that it's disabled.
Best answers
  • jguerdat
Chad4444
Thank you.  I had to go to routines, then under both arm away and arm home routines, select the individual floodlight cameras and deselect the "floodlight on" option when motion or audio is detected.
  • 2 Replies
  • 547 Views
