video doorbell won't connect to my vmb3000.
  • 1 Reply
  • 1044 Views
joe99
do I need a vmb4500 or 5000 to record video for 30 days.
I currently have 4 vmc3030 cameras connected to my base station vmb3000.
Do I need 2 base stations ?
@joe99 wrote:
avd1001b (video doorbell) won't connect to my vmb3000.
Correct.  It's not compatible with that base station.  https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
It will connect to your home wifi w/o a base.
The simplest option is to get a subscription for the doorbell.
You can also get a new base, and use direct access to local storage in the app.  You'd want either a VMB4540 or a VMB5000 - not a VMB4500.
There are limitations to direct access though:
  • recordings are only available from the app (not the browser).
  • recordings are only available using the primary account (not friend accounts)
  • no ability to make manual recordings or snapshots
  • no thumbnails
  • remote access requires router settings changes that some find difficult - and won't work on some networks, including Starlink and T-mobile broadband.
Also, activity zones require a subscription, and often are needed with the doorbell (since it cannot be aimed once installed).
  • no thumbnails
  • 1 Reply
  • 1045 Views
