video doorbell installation
I have had a good experience with my Arlo camera, so I decided to add the video doorbell. the installation was smooth up until the time it came to connect it. I have a base station. I used the app to try connecting through that. it couldn't find the doorbell. i reset the base station, no luck. I tried connection without the base station by scanning the QR code. it read the code, but no connection. Even more frustrating was I tried the chat feature on the app. I waited from position 15 until I got to 4, then it disconnected me. I tired on the computer. from position 12 to connected. it disconnected from chat while I was typing my first message. I called tech support. there's an endless loop ie. press 1 for tech support > COVID message > press 1 for tech support endlessly. press 0 and it hangs up on you.
I'm going to try again tomorrow. If I get the same lack of response, I'm boxing this up and returning and ring brand doorbell.
It may just be a bad doorbell. Swapping at the store would hopefully help. Also, be sure your doorbell transformer is up to the specs needed.
cwke,
What is the LED behavior on your doorbell when going through setup?
I'm having the exact same problem. I was going to try the helpline tonight, now that seems futile. Please let me know what your outcome is
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
