video doorbell hook-up to intercom system AVD 1001
  • 1 Reply
  • 958 Views
RickR2369
doorbell rings continuously after installing powerpack to Nutone intercom IMA 4006
Not surprising, since the Nutone IMA 4006 isn't compatible with Ring doorbells either.
If you google, you'll find some folks who've modified the wiring and gotten it to work with Ring.  If the mod actually works with Ring, it likely would work with Arlo.  It's not something I tried (and I'm not making a recommendation one way or the other).  You'd be "on your own".
  • 1 Reply
  • 959 Views
