Newly installed Arlo Video Doorbell causing the chime box to buzz as shown in the video. Any thoughts on how to fix are greatly appreciated.
Have the same problem and would like to know the next steps to take.
I suggest checking the transformer voltage and power (VA) specs next, and also measure voltage if you can.
Setting the powerkit switch to X (bypass mode) should stop the issues, but the chime won't ring if you do that, so that is at most a temporary workaround.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
