We experienced a power outage recently and when the power came back on, the doorbell chime (mechanical) triggered over and over without stopping. I ultimately switched off the breaker to the doorbell/chime. I decided to perform a reset on the doorbell unit, so I powered the breaker back on then inserted a paperclip into the reset hole on the back of the device and kept it pressed for about 8 seconds. Now the video doorbell triggers the chime as per normal, but the device will not connect to the basestation. The light ring slow pulses white. I ran through the setup steps again, and the doorbell cannot be found by the basestation. I also tried connecting directly to Wi-Fi which also failed. I am unable to get the video doorbell to display a solid white light ring. I'm a bit at a loss, thinking the doorbell may have partially died. Anyone have thoughts on what else I can try before I buy a new video doorbell?
TIA,
Roger
monzarottie,
This is an indication that the factory reset may not have completed. Try factory resetting the device again and test to see if you still experience the same behavior.
monzarottie,
Along with the factory reset, did you also remove the doorbell from the app? You will need to remove, reset, and re-onboard the doorbell as if it were new. Do you still experience the same behavior?
Thanks for your suggestion. Sorry. My original post should have specified. Yes, I removed the doorbell from the app/system, performed a device reset, and attempted to re-add the doorbell as if it were new. I can’t get a solid white ring light, just a pulsing white light. It triggers the chime (not Arlo) just fine.
monzarottie,
Thanks James,
It finally synced after three more reset attempts. I'm back in business. Appreciate your help.
Roger
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
