Video doorbell (wired) is offline
Retired_Member
Not applicable
2021-04-10
04:10 PM
Had a 15hr power outage. Other cameras came back online fine. Door bell not. It rings. It lights when you press it but no camera. I don’t want to take it off the door as it was a pain in the butt to install due to angle and having to use wire extenders. I’ve reset breaker multiple times for up to 30 min off, reset the hub and tried to reinstall doorbell but it can’t be “found”! I’m pulling my hair out.
InJayMama,
If you've reset the SmartHub, you will also need to reset the doorbell before resyncing.
Follow the instructions here to reset the doorbell: How do I reset my Arlo Essential Video Doorbell?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
