Video doorbell transformator
Does this transformator works ?
https://www.elektramat.nl/beltrafo-8v-12v-24v/?utmsource=GoogleShopping&utmcampaign=Beltransformator...
@Jamesdean1974 wrote:
Does this transformator works ...
The 24volt tap would give you the correct voltage, but the transformer power is only 8 VA, which is below the 10 VA spec. It might still work.
These two would meet all the specs if you select the the proper voltage:
https://www.elektramat.nl/413096-leg-modtrafo-12-24v-25va/
Likely there are other choices, but
https://www.vekto.nl/beltrafo-15va?gclid=CjwKCAiA9JbwBRAAEiwAnWa4Q9kwOOZskG9vEAIgw_4aA8GgpryafCBDDKJ...
Thanks. Will this work as well!
It's within the spec.
BTW, it's best to remove the ?gclid=XXX bit from the links when you post them. That can create issues later on when others try to access them. The gclid is a tracking id.
There are cheaper transformers on the market with de desired specs. So I guess I will find one. Is there any news when the video doorbell will be launched in Europe ? Or do I need to start a new topic on that question?
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
