  • 4 Replies
  • 2293 Views
Jamesdean1974
@Jamesdean1974 wrote:
Does this transformator works ...
The 24volt tap would give you the correct voltage, but the transformer power is only 8 VA, which is below the 10 VA spec.  It might still work.
These two would meet all the specs if you select the the proper voltage:
https://www.elektramat.nl/ts-2512-24-c-abb-veiligheidstrafo-25va-4-m-tbv-ring-deurbel-en-nest-hello-...
https://www.elektramat.nl/413096-leg-modtrafo-12-24v-25va/
Likely there are other choices, but
Jamesdean1974
Thanks. Will this work as well!
https://www.vekto.nl/beltrafo-15va
It's within the spec.
BTW, it's best to remove the ?gclid=XXX bit from the links when you post them.  That can create issues later on when others try to access them.  The gclid is a tracking id.
Jamesdean1974
Thanks for the support!
There are cheaper transformers on the market with de desired specs. So I guess I will find one. Is there any news when the video doorbell will be launched in Europe ? Or do I need to start a new topic on that question?
  • 4 Replies
  • 2294 Views
