Also will i get the 3mo free trial still if i already am at a 5 camera limit? I have the Pro 2's with no subscription.
Thanks!
Prototypechad,
There is no "2 doorbell limit". I'm not sure what you're referring to by that. Yes, you will still get the 3 month trial. Video Doorbells behave the same as a camera from a subscription/camera limit perspective.
Prototypechad,
Thanks for the clarification. The 2 doorbell limit is exclusive to doorbells synced to a base station or SmartHub. Each base station or SmartHub on your account can support up to 2 doorbells (audio or video). If you have more than one base station or SmartHub, you can have 2 doorbells synced to each of them.
If your Arlo Video Doorbell is synced directly to your router, this limitation is not present.
Prototypechad,
Yes. Take a look here: How do I connect my Arlo Video Doorbell directly to my WiFi router?
@Prototypechad wrote:
It appears when its connected via router vs base station i can't setup cross triggers? Such as doorbell motion turns on my Arlo lights.
Correct.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
