Video Phone Call - Turn off
  • 29 Replies
  • 168021 Views
  • 66 Likes
  • 14 In Conversation
UnreadCoyote3
Hello - I just installed the Video Doorbell and wanted to know how you can turn off the video phone call?  Right now when someone presses the doorbell my phone will start ringing to accept the phone call from Arlo.
Thank you
For those who were previously experiencing this issue. Please download the latest version of the mobile app from the app store and test again.
29 REPLIES 29
UnreadCoyote3
Thinking about it, I understand the point of the call... I guess maybe the question is if there is a way to do just notifications vs calls..
Thanks!
UnreadCoytoe3,
You can enable "Silent Mode" if you do not want to receive calls. For more information on this, take a look here: How do I receive incoming calls on my smartphone from the Arlo Audio Doorbell?
jhainzl
With the video doorbell, silent mode disables both the phone call and the chimes. We need a way to stop the phone call (when we are home) but still activate the chimes.
Skibum79
Just purchased and installed the video door bell and am experiencing the same issue.  Turning on 'silent' mode disables both the chime and call feature.  These need to have separate toggle buttons in the app
WasteManagement
I desperately need this feature. Please have an option to disable calling my phone while leaving the chime enabled.
Diepe
Same problem, just bought the video doorbell, need to deactivate the calls but keep the chime activated
mohsiddiqui
Has anyone figured this out yet? I also only want to turn off the call function but leave my normal chime on
mohsiddiqui
Just installed an Arlo Video Doorbell. For the most part its great, however getting a call every time the bell rings when I am home is incredibly annoying.
Is there a way to turn off the video call function but still have my chime function? I know silent mode is an option but that kills the video call and the mechanical chime.
jhainzl
According to Arlo Support, this option is not available at this time. Seems kind of ridiculous (and annoying) to hear the chimes and get a phone call while you are home. Too bad, because Arlo just updated the App a day or two ago.
jbromheadsd
Up until the last ios app update 2.12.2 the workaround I used was:
Save contact from 'call' that Arlo makes as a contact, then change ringtone to be just a tone (less obtrusive - but it does repeat every few seconds), but finally I set this contact to have a silent ring tone
But now notifications aren't happening at all
Tried to report via support ticket option but get an error
Filed a one star rating on Apple App store alongside many issues since Xmas 2019
Thinking about returning my doorbell
jbromheadsd
Oh, and by the way the feature to separately silence original chimes or phone notification was added to the Arlo Audio Doorbell App, but is not available with video doorbell
Yes, and it clearly is something that is needed in the video doorbell as well.  It also won't work with the Arlo Chime (and it would be very nice if it did).
jhainzl
Another Arlo App update with lots of changes, but no fix for Silent Mode. Still looking for option to stop phone call but keep chimes active. Don’t need a phone call when sitting at home.
jjzeng21
same problem here, just got the arlo video doorbell, need to turn off the phone call but keep the chime on
Sara999
I completely agree that Arlo needs to add a way to be able to stop phone calls without silencing the chime. It’s pretty silly that they didn’t think of that...
The two “workarounds” until they do fix it:
1. Save the doorbell as a contact. Buy a “silent” ringtone from the App Store and assign it to the doorbell.
- Still annoying to have a bunch of missed calls while at work but not bad.
- I use this because sometimes I DO want to be able to interact with the doorbell and it’s an easy fix to hear it again (change the ringtone back).
2. Save the doorbell as a contact. Block it. You can unblock it later if you want. This is probably better for someone who never uses that feature.
SJohannsen
Just want to add my support to a distinct option to turn off the phone call. Silly that doesn't exist. I have a doorbell, it works fine. Silly to have the only options be to have both ring, or neither.
scarson28
Adding to the list of people who can’t wait for a fix for this problem. I do not need a call every time someone rings my doorbell. Sometimes the mail carrier or the UPS person rings the bell and leaves. Very frustrating.
SJohannsen
Noticed in the latest app version 2.19.1.28105 (Android), Silent mode has toggles for Incoming Call and Traditional Chime, when you turn it on. I believe that should allow you to turn off the call, but keep the doorbell, if set properly. Doesn’t seem to work right, but it is there now.
scarson28
Great, thanks for the reply. I have iOS.
SJohannsen
I have an iPhone as well. I see the same options in version 2.19.2 (993) Wife’s phone at 2.19.1 did not have the option. Updating the app via the store got it. Must be quite new.
scarson28
I see it. Thanks for the follow up tip.
jhainzl
I saw the silent option choice once on my iPhone. I tried it and it didn’t work. Now the option doesn’t show. Arlo, how hard could this be?
SJohannsen
Turn silent off and back on. I noticed the options didn’t show up if I left the screen and came back. No idea if they were persistent or not. Also not clear what happens with multiple clients. Is this a universal account setting, and last client wins, or what? Feature needs work.
SJohannsen
Hey, I think it just worked. The Amazon guy rang my doorbell (surprise) and my chimes went off but no phone call. I had set Silent mode for chime but no call on one device, and didn’t touch it on any other. Now, if that could be in some setting that makes more sense than Silent Mode (shades of silent) and be automatically variable by Home/Away/Vacation etc. we could get some real use out of it. Not calling me on the phone when I’m sitting on the couch is a good start though.
  • 29 Replies
  • 168022 Views
  • 66 Likes
