  • 7 Replies
  • 1606 Views
caliphat71
Need help. Installed and it worked fine. Running off the Arlo hub like my other Arlo pro cameras for a few days. I added another pro and then it went offline. Reset it several times and it found it. Worked for a split second then nothing. I’m on the plan so I can have enough cameras. I have 5 pros going. Is it a bandwidth issue? Thanks for any help.
7 REPLIES 7
Dannybear
Are you trying to live stream all your cameras at the same time?
The limit for live streaming is 5 cameras at same time, including the door bell camera regardless of subscription status.
You’re account is limited to 5 cameras without subscription.
caliphat71
I got suckered into a subscription and it still doesn’t work. I looked at some Amazon reviews, and apparently the arlo doorbell isn’t compatible with some base stations. Totally ridiculous. How can you make such a product?
The compatibility list is here:   https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility You can also connect the doorbell directly to your home WiFi.
I'm puzzled by the subscription comment, since the doorbell install would automatically have opted you into a 3 month trial.  Arlo support would not have have charged you (assuming you reached them and not a scammer).  https://kb.arlo.com/000062119/How-can-I-avoid-Arlo-support-scams
caliphat71,
Is there any LED behavior on the doorbell when you press the button?
caliphat71
No.  I only live stream one at a time.  It won't connect even when there is no live streaming.
caliphat71
It's compatible according to the list.  I connected to my wifi and it worked for a day, then went offline again.
caliphat71
Yes.  It connects just fine.  It lights and responds just like the installation instructions say it does. I have done it at least a dozen times.  It works then goes offline after a few days when on the Arlo hub and in one day after connected to WiFi.
  • 7 Replies
  • 1607 Views
