Sound detection issues
  • 6 Replies
  • 4230 Views
Dobefan
For some reason, the system just started recording videos based on sound/audio rather than motion.  The audio box under the mode section is missing and there isn’t a way to u check the box.  We’ve received over 20 notifications in the last 30 minutes.  Is there another way to stop the audio detection?
Dobefan2
The video doorbell seems to have corrected itself and we are no longer gettin videos activated from audio rather than motion detection.
The issue is resolved.
6 REPLIES 6
Dobefan,
Are you logged in on the primary account? Are you using the mobile app or the web client? Do you experience the same behavior from both?
Dobefan2
Yes, I tried both.  I was on the primary account and the web and neither gives me the option to uncheck an audio detection box for the Arlo Video doorbell.
Clendinning
I have noticed the same thing. When I first got the Video Doorbell system, the trigger areas seemed to work just fine. Now I get an overwhelming number of false triggers. Today, I noticed that many of the triggers had no motion at all, but there were loud sounds apparent. It seems like audio triggering has been enabled on my system and I have no way to adjust sensitivity or turn disable the feature, which has now become a nuisance.
Consider rebooting the Arlo Video Doorbell. You can do this by navigating to Settings > My Devices > select your doorbell > Restart
Allow the doorbell to boot back up and test again to see if you still experience the same issue.
Clendinning
On the other hand, turning off the microphone in the audio settings preferences seems to have reduced my false triggers drastically. I’ve gone down from more than 50 a day during the weekends and 30 a day on weekdays too almost none. It would be interesting to see if anyone else has the same result.
Dobefan2
  • 6 Replies
  • 4230 Views
