Smart Hubs Out of Stock
  • 1 Reply
  • 2045 Views
crashed97tsi2
I just bought the wired doorbell and apparently it will not sync with my existing base station (the VMB3000). I have had this base station for quite awhile so I figured it was time to upgrade anyway.
Only problem is, you can't find just the base station anywhere. I see plenty of $500 camera packages with the base station everywhere but no luck with just the base station.
I know the doorbell will work on its own, but that is not how I would like to set it up. Does anyone know when the base stations will come back in stock?
I agree that standalone bases and hubs seem to be out of stock. However, in your case I don't see an advantage in upgrading. If you're happy with the existing 3000 you won't get additional functionality with a new hub. If your reason for upgrading is to use local recording or have a siren in the base, that's different but that's not what you're telling us.
  • 1 Reply
  • 2046 Views
