Re: No video on 1536sq when answering call
- Email to a Friend
I do not think that downgrading video should be the solution. Is Arlo aware of this bug and also very important when will this bug be fixed.
- Email to a Friend
Jamesdean1974,
This often is a symptom of poor speeds, limited bandwidth requires lower resolution to be selected. What are your download/upload speed for the mobile device that you're using?
- Email to a Friend
Thanks for your answer.
That cannot be issue though.
My mobile speed is 225/65 mlMbps on 4G. The problem also exist when I am at home on WiFi ( full range ).
So the bandwidth is not the issue .
- Email to a Friend
The doorbell is connected to your router, not your phone. Thus, the home network speeds are the important part, especially upload. In addition, the connection between the doorbell and router can be at fault if there's a poor signal strength or quality issue in that connection.
- Email to a Friend
But to answer your question. Both signals upload and download are strong enough. I am able to watch live stream on high settings without any problem.
- Email to a Friend
- Email to a Friend
Jamesdean1974, Milanovi
Which mobile device are you using that experiences this issue? (iOS or Android)
What is the model and OS version on that device?
- Email to a Friend
Arlo Video Doorbell
