My door bell videos disappear
  • 1 Reply
  • 366 Views
Earlhaskell
So the videos that are recorded from my door bell and the camera that is also triggered in the rule either never show up or will be in the library for a few minutes and then disappear. I have an active paid subscription. Sometimes I can disable the doorbell rule and enable it and the videos will be there for a day but then disappear. Tried to go through there tech support but they were useless ( Only know how to follow a script that was no help).
Does a manual recording also disappear?
Are you using activity zones?
If you remove all filtering from the feed settings?
  • 1 Reply
  • 367 Views
